I use docker to install documentServer, but when i start test example and creat an new doc, it always display loading document
Document Server version:6.4.2
docker toolbox
OS: windows server 2008R2
Browser version: chrome 109.0.5414.120
docker toolbox
HI @exampleswz
Wait, if I’m not mistaken, Docker on Windows is supported from Windows Server 2016 and higher
ONLYOFFICE DocumentServer has the latest version 7.4
And we are testing it with this Software requirements:
I haven’t tested the docker installation on windows.
Try using newer versions of windows or windows server.
i reboot the docker, then the problem are resolved, maybe is due to insufficient ram
I cannot say for certain at the moment.
I would like to remind you once again that the current version is 7.4.2
you are right7.4.2
it seems like this is a random event,how to close this subject
Topic does not require closure
We are glad to hear that the problem is no more.
