test文档.doc (60 KB)
Some pages will be lost when using this document to open onlyOffice, which is opened by the url
Hello @zhengzetao, we are currently analysing the issue
Do you have any problems importing with this document? Can you repeat the problem
Hello @zhengzetao, we’ve managed to reproduce the issue and currently are still analysing it, I’ll share when I have more information
Thank 。。。。。。。。。。。。。。
Hello @zhengzetao, we’ve reproduced the above-mentioned issue and concluded that the issue is related to the known bug, we have added your request to it, thank you for sharing!
Will this bug be fixed in the next release? We are in urgent need of normal operation. What are the alternatives。
thank
Dear @zhengzetao
We are still working on the mentioned bug in this thread. Unfortunately, we cannot provide an ETA at the moment, we will update this thread once we have something to share.
First of all, thank you for the use of this tool, and then may I ask when this bug can be solved? It has been a long time, and we are in a hurry to use it.
First of all, thank you for the use of this tool, and then may I ask when this bug can be solved? It has been a long time, and we are in a hurry to use it.··
Unfortunately, there is still no particular timeline for this bug for now, we will inform you as soon as there is news on the version with the bugfix, sorry for the inconvenience
