Could you make the shadows that you can activate on a standard graphic editable? For example I would like to have a much more blurry and less transparent shadow than the default one.
Thanks for your work!
Hello, @GutmenschAlex
Please describe your idea in details.
Include pictures with descriptions if possible.
Hello Nikolas, thanks for the quick response.
Currently I am only able to select if an object has a shadow or not in the spreadsheet editor:
Sometimes this shadow doesn’t meet the look I need. Thus I would love to be able to adjust various parameters of the shadow - for example: Color, Blur, Transparency
Thanks!
Thanks for making your suggestion.
We are working on it already (internal track number - 59823).
I’ve added your request to mentioned suggestion.
