Add RTL support?
I have a copy. 8.2.2.22 have installed it, but unfortunately there is still a problem with the word upside down in the spreadsheet section, or Excel. How long will this problem be fixed? I really need a fix for this issue.
I hope this problem is resolved soon by the good team of this company, because we have many clients who have been directly involved in this issue and there has been a lot of dissatisfaction.
If you are representing a company that utilizes ONLYOFFICE Docs in their app and you have active license, then you should contact our Sales Department to discuss the speed-up query:
I am using the free version of this software and have connected it to Nextcloud
I have installed it directly on Debian Linux version 12.
The latest version is 8.2.2.22.
What should I do to fix the problem of Persian language being written upside down in the spreadsheet?
@hghaderi As the discussion on Persian language has been started in this separate topic, let’s continue it there
Hello Hussam,
Could you please, specify the OS where you have installed Docs?
Please, send us a screenshots how the Arabic fonts are displayed.
ALT+Enter function to add new line in spreadsheet:
Please, make sure that the cursor is moving inside the cell, not just the cell is selected. If still does not work , specify the browser you use, and try this function in incognito mode
Hello Hossam,
Thank you for the update.
For the Arabic font issues, if the font is not installed on your device, then its display could be not correct. To avoid such issues, please install the Arabic fonts you usually use following this guide:
Adding new fonts to ONLYOFFICE Desktop Editors - ONLYOFFICE
You can find free fonts at:
خطوط عربية، بنوط/فونتات، للمعاينة والتحميل
For the issue with ( Alt+ Enter ) in Spreadsheet editor, we could not reproduce it on our side, please, make sure to update to the new version 8.3 which should be launched today, and check whether this issue persists
Hello @Hossam
I believe they were referring to the Incognito Mode of a browser, but as I can see you are using Desktop Editors, so you can ignore that advice.
As for the ALT+Enter issue: did you manage to reproduce the issue after updating to the version 8.3?
Please start a new topic on the issue you’ve faced during an update/installation. This topic is related to RTL support, it is better not to mix up different topics. Thank you for understanding.
Hello Hossam,
Please, note that the RTL support for the spread sheet editor, still not available. It is planned for 8.4 release.
For the issue, with (Alt + Enter)
Please, provide us with the your OS version, and the way ONLYOFFICE has been installed.
Hello Hossam… I just tried on my side that the atl+enter does indeed work. You should make sure that the cursor is within the cell, “double-click on the cell”… I do use 8.3 version on Arch Linux also…
And please guys, I mean the dev team…
I hope that the RTL support gonna also support the bilingual sheet. As in my case, I do work sometimes on bilingual invoices (French + Arabic) as for now, I’m forced to use LibreOffice for such case…
Thank you all
Hey… the right alt which is actually called altgr has different fonction than the left one… and no… I’m used with the left alt + entrer for getting a new line… I don’t know if it is possible to reconfigure that key… well… with linux of course it possible but I guess better to advice you to just get used with the left alt… many other programs also react differently between these two keys…
Best regards.
Ps: to reconfigure any kind of keyboard key is at the os level… onlyoffice or other software has nothing to do with this…
Yes, if the OS does not support such function, or not configured, it could not work.
Helllo @Hossam
Here is your answer: Linux console/Keyboard configuration - ArchWiki
and not to be rude, but I think you may open a topic on Arch Linux forum for more question related to keyboard mapping…
Easy there detective. I came here to discus OnlyOffice, not to apply for a job. Didn’t realise helping require a full background check. If my advice works, great. If not feel free to ignor it… no need for personnal investigation
Dear users,
This is a technical forum where its members try to help each other. We appreciate the impact of the community on product improvement, but we ask you to avoid discussing abstract (non-technical) topics and refrain from promoting third-party resources.
@Hossam I will edit your post to remove LinkedIn/website data. It seems off-topic.
Dear Hossam,
Please, keep the topic related to the technical issues, and avoid any other side topics.
For the question, with Alt+Enter \ specify your OS and its version (built) ,and we will check on our side.
8.4 release, is planned for Q2 2025
