Add ability to change roundness of rectangle conrners
Hello!
There is a shape called Flowchart (actually it is rectangle with rounded corners). In MS PowerPoint you have yellow anchor for changing roundness of it’s corners. OnlyOffice also have this anchor for different shapes but not for Flowchart. It will be extremely useful to be able to change corner radius. I hope you will add this functionality!
Hello @user_7543,
Thank you for sharing your idea, we will review it
Unfortunately, it is not technically possible to implement this suggestion because the shape variables are defined in the format and cannot be changed. As an alternative, it is only possible to use a similar rounded rectangle shape from another group, for example, Rectangles > Round Corner Rectangle
Oops :sweat_smile:, sorry. I haven’t found it before because Rounded Rectangle was in other place in PowerPoint. I will use it instead. Maybe rectangles and lines can be put in the top like in PowerPoint because they are used more often.
