Hi,my friend
Recently I have some new troubles
How does excel switch sheets
Looking forward to your reply
Hi,my friend
Hello @mao
Please let us know your ONLYOFFICE Documents app version, also let us know exact version of your device and android version.
Also please take a look at this guide: Manage existing sheets - ONLYOFFICE
Hi Alexandre!
Thank you for your reply
We are currently using 7.2.2
Attached after,test(deviceModel~osVersion~browserName~browserVersion)Please
reference
I already read the link, but the setting for mobile is not found
Thanks
Ah, now I got it. You are using stand-alone Document server, am I right? So does the issue reproduce when you open xlsx files via mobile browser?
If so, is it possible to update your installation do Document server v.7.3.2 and double check the situation?
If I misunderstood the situation, please clarify it.
Hey bro!
We have upgraded to 7.3.2
Unfortunately, I still can’t find a place to switch sheets
Maybe you can demonstrate it to me on mobile
Looking forward to your reply!
Hello @mao
Please clarify if you have integrated Document server with any storage (Nextcloud, Seafile, etc.). Let us know exact version of your storage and connector app.
Hi Alexandre
The version we use is:
The current test is shown in the image above
We used 7.3.2.8 for the development version, but that doesn’t work either
Thank you for your reply.
Did you integrate the Document server with some storage? or did you run your tests on the integrated example of storage?
