I installed OnlyOffice Desktop 7.4.1 in Debian 12, I open a file located on a network resource (samba shared folder), for example * .docx, while the second user on the local network also has the opportunity to open the same file. Both users can simultaneously make changes to this one file, but the changes are not saved, there are no notifications that the file is opened by another user, a temporary (blocking) file, as in LibreOffice, is not created. How to prevent multiple users on the local network from opening the same file at the same time?
Hello @imartynov
Please accept our apologies for this situation. We know about described behavior and we are working on it already. I will update this thread when we have something to share.
Sorry for inconvenience.
Hello @Alexandre
Is there already a solution available for the described behavior? We would love to work with OnlyOffice in our enterprise - since this is a real critical scenario for us (central Fileserver where user open files in desktop editor) we need a perspective whether this is on the shortterm roadmap.
Hello @bNausn
Unfortunately, we are still working on the mentioned bug in this thread, and we will update this thread once we have something to share.
If you want to speed up the situation, please contact colleagues of mine and discuss possible options: Get dedicated support
Please accept our sincere apologies for the length of the situation.
