Since updating our document server to 7.4 we can no longer view documents in Nextcloud. The document server runs in a 20.04 container, installed using packages and running behind nginx. When trying to view a document the OnlyOffice frame loads, but then fails reporting download failed. There is nothing in the err.log, but in out.log for the convertor I see
Error: DNS lookup 192.168.11.50(family:4, host:) is not allowed. Because, It is private IP address.
It’s not clear to me which config is actually in operation, default or production-linux (How do you choose?) but I have tried to add:
"request-filtering-agent" : { "allowPrivateIPAddress": true, "allowMetaIPAddress": false },
to both configurations as described here:
https://helpcenter.onlyoffice.com/installation/docs-developer-configuring.aspx
With no luck.
Has something changed with 7.4?
