Hello, i’m experiencing the following issue.
Nextcloud:
ServerException
Server error: `GET http://192.168.1.5/healthcheck` resulted in a `502 Bad Gateway` response: <html> <head><title>502 Bad Gateway</title></head> <body> <center><h1>502 Bad Gateway</h1></center> <hr><center>ngin (truncated...)
My OnlyOffice docker-compose
version: "3.8"
services:
onlyoffice-documentserver:
image: onlyoffice/documentserver:latest
container_name: onlyoffice-documentserver
depends_on:
- onlyoffice-postgresql
- onlyoffice-rabbitmq
environment:
- DB_TYPE=postgres
- DB_HOST=onlyoffice-postgresql
- DB_PORT=5432
- DB_NAME=onlyoffice
- DB_USER=onlyoffice
- AMQP_URI=amqp://guest:guest@onlyoffice-rabbitmq
# Uncomment strings below to enable the JSON Web Token validation.
- JWT_ENABLED=true
- JWT_SECRET=secret
- JWT_HEADER=Authorization
- JWT_IN_BODY=true
ports:
- "80:80"
- "443:443"
stdin_open: true
restart: always
stop_grace_period: 60s
volumes:
- /mnt/[PRIVATE]/onlyoffice/Data:/var/www/onlyoffice/Data
- /mnt/[PRIVATE]/onlyoffice/logs:/var/log/onlyoffice
- /mnt/[PRIVATE]/onlyoffice/cache:/var/lib/onlyoffice/documentserver/App_Data/cache/files
- /mnt/[PRIVATE]/onlyoffice/files:/var/www/onlyoffice/documentserver-example/public/files
- /mnt/[PRIVATE]/fonts:/usr/share/fonts
onlyoffice-rabbitmq:
container_name: onlyoffice-rabbitmq
image: rabbitmq
restart: always
expose:
- "5672"
onlyoffice-postgresql:
container_name: onlyoffice-postgresql
image: postgres:12
environment:
- POSTGRES_DB=onlyoffice
- POSTGRES_USER=onlyoffice
- POSTGRES_HOST_AUTH_METHOD=trust
restart: always
expose:
- "5432"
volumes:
- /mnt/[PRIVATE]/onlyoffice_postgresql:/var/lib/postgresql
networks:
default:
external: true
Nextcloud & OnlyOffice is running on the same Pi 5 server via docker.
How can i solve this?
