[2022-12-08T09:31:38.544] [WARN] [localhost] [docId] [userId] nodeJS - Express server starting…
[2022-12-08T09:31:38.554] [WARN] [localhost] [docId] [userId] nodeJS - Failed to subscribe to plugin folder updates. When changing the list of plugins, you must restart the server. File system | Node.js v19.2.0 Documentation
[2022-12-08T09:31:39.009] [WARN] [localhost] [docId] [userId] nodeJS - Express server listening on port 8000 in production-windows mode. Version: 7.2.1. Build: 34
[2022-12-08T11:41:59.312] [ERROR] [localhost] [127.0.0.1new.docx11670488499906] [uid-1] nodeJS - postData error: url = https://localhost:449/example/track?filename=new.docx&useraddress=127.0.0.1;data = {“key”:“127.0.0.1new.docx11670488499906”,“status”:1,“users”:[“uid-1”],“actions”:[{“type”:1,“userid”:“uid-1”}],“token”:“eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJrZXkiOiIxMjcuMC4wLjFuZXcuZG9jeDExNjcwNDg4NDk5OTA2Iiwic3RhdHVzIjoxLCJ1c2VycyI6WyJ1aWQtMSJdLCJhY3Rpb25zIjpbeyJ0eXBlIjoxLCJ1c2VyaWQiOiJ1aWQtMSJ9XSwiaWF0IjoxNjcwNDk2MTE5LCJleHAiOjE2NzA0OTY0MTl9.7yCKdwzOuTl4_7Dp9-iokEma1Ml5s68eLbRhF73l_CM”} Error: self signed certificate
at TLSSocket.onConnectSecure (_tls_wrap.js:1515:34)
at TLSSocket.emit (events.js:400:28)
at TLSSocket._finishInit (_tls_wrap.js:937:8)
at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:709:12)
[2022-12-08T11:45:23.931] [ERROR] [localhost] [127.0.0.1new.docx11670488499906] [uid-1] nodeJS - postData error: url = https://localhost:449/example/track?filename=new.docx&useraddress=127.0.0.1;data = {“key”:“127.0.0.1new.docx11670488499906”,“status”:1,“users”:[“uid-1”],“actions”:[{“type”:1,“userid”:“uid-1”}],“token”:“eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJrZXkiOiIxMjcuMC4wLjFuZXcuZG9jeDExNjcwNDg4NDk5OTA2Iiwic3RhdHVzIjoxLCJ1c2VycyI6WyJ1aWQtMSJdLCJhY3Rpb25zIjpbeyJ0eXBlIjoxLCJ1c2VyaWQiOiJ1aWQtMSJ9XSwiaWF0IjoxNjcwNDk2MzIzLCJleHAiOjE2NzA0OTY2MjN9.arQA0ID3yUlZReSBL86544hRO16IcE1-wU5sTB47Bdg”} Error: self signed certificate
[2022-12-08T12:04:12.804] [ERROR] [localhost] [127.0.0.1new.docx11670488499906] [uid-1] nodeJS - postData error: url = https://localhost:449/example/track?filename=new.docx&useraddress=127.0.0.1;data = {“key”:“127.0.0.1new.docx11670488499906”,“status”:1,“users”:[“uid-1”],“actions”:[{“type”:1,“userid”:“uid-1”}],“token”:“eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJrZXkiOiIxMjcuMC4wLjFuZXcuZG9jeDExNjcwNDg4NDk5OTA2Iiwic3RhdHVzIjoxLCJ1c2VycyI6WyJ1aWQtMSJdLCJhY3Rpb25zIjpbeyJ0eXBlIjoxLCJ1c2VyaWQiOiJ1aWQtMSJ9XSwiaWF0IjoxNjcwNDk3NDUyLCJleHAiOjE2NzA0OTc3NTJ9.CMBZREsaoJ64HpRy0ZPfWGEs8OmkIsKViN5_h2ZTqyw”} Error: self signed certificate
[2022-12-08T12:09:41.200] [ERROR] [localhost] [127.0.0.1new.xlsx1670497774657] [uid-1] nodeJS - postData error: url = https://localhost:449/example/track?filename=new.xlsx&useraddress=127.0.0.1;data = {“key”:“127.0.0.1new.xlsx1670497774657”,“status”:1,“users”:[“uid-1”],“actions”:[{“type”:1,“userid”:“uid-1”}],“token”:“eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJrZXkiOiIxMjcuMC4wLjFuZXcueGxzeDE2NzA0OTc3NzQ2NTciLCJzdGF0dXMiOjEsInVzZXJzIjpbInVpZC0xIl0sImFjdGlvbnMiOlt7InR5cGUiOjEsInVzZXJpZCI6InVpZC0xIn1dLCJpYXQiOjE2NzA0OTc3ODEsImV4cCI6MTY3MDQ5ODA4MX0.yBjPYjw0P1hpTst3Xss9oIeLv-h7pRCQWaSinpiGqjI”} Error: self signed certificate
[2022-12-08T13:05:36.760] [ERROR] [localhost] [127.0.0.1new.docx1670501133074] [uid-1] nodeJS - postData error: url = https://localhost:449/example/track?filename=new.docx&useraddress=127.0.0.1;data = {“key”:“127.0.0.1new.docx1670501133074”,“status”:1,“users”:[“uid-1”],“actions”:[{“type”:1,“userid”:“uid-1”}],“token”:“eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJrZXkiOiIxMjcuMC4wLjFuZXcuZG9jeDE2NzA1MDExMzMwNzQiLCJzdGF0dXMiOjEsInVzZXJzIjpbInVpZC0xIl0sImFjdGlvbnMiOlt7InR5cGUiOjEsInVzZXJpZCI6InVpZC0xIn1dLCJpYXQiOjE2NzA1MDExMzYsImV4cCI6MTY3MDUwMTQzNn0.rBotWfCxMAbweGIp3tt90cc2bg1niARyjY1okIkMH_I”} Error: self signed certificate
The problem is that document server does not validate self-signed certificates by default.
The best way to avoid errors is to set rejectUnauthorized
to false
in default.json, which can be found under this directory C:\Program Files\ONLYOFFICE\DocumentServer\config\
After you have made changes to default.json, make sure you restart all ONLYOFFICE Document Server services in Windows Services. This way the changes will be implemented.
Yes thank You it is WORKING
I’m glad we’ve managed to solve this issue.
Thanks for your patience!
