When hiding columns in tables, the hiding area is not indicated in any way (a double line like in Excel), which is inconvenient
Do you want to: Suggest a feature
For feature suggestions, describe the result you would like to achieve in detail
OS version: MacOS
Hello @Pavel71,
What is the version of Excel that you are using?
Could you please demonstrate the double line you are referring to?
