Some “undo” troubles editing by Desktop Editors a spreadsheet on DocSpace.
While editing a spreadsheet in DocSpace, I edit same file by Desktop Editors and copy cell then paste other, and press ctrl-z, undo isn’t executed.
While previewing a spreadsheet in DocSpace, I edit same file by Desktop Editors and change the values of cell, and press ctrl-z, undo is executed but not reflected in preview.
Hello @nishigaki,
Please provide a screen recording of the issue reproduction steps for better clarity
It took a long time to reproduce, but it is difficult to reproduce. The data below shows four problems with similar issues.
https://nisigaki.onlyoffice.com/s/xPnD-Wc-RTNDQ-k
Can you please add the timing and a description for each of the four issues? I was able to understand the first one based on your explanation, but the others are not quite clear
The following occurs.
0:20 I entered values for A1:A2 in desktop editors, then preview was updated.
0:26 I executed undo in desktop editors, but preview was not updated. This is first problem.
1:30 I changed values of A1:A2 from “2” to “3” in desktop editors, then preview was updated.
1:40 I closed a preview and reopened, but values of A1:A2 are old value “2”. This is second problem.
2:07 I changed values of A1:A2 from “3” to “4” in desktop editors, but preview was not updated. This is third problem.
2:48 I changed values of A1:A2 from “4” to “5” in desktop editors, copied A2 and pasted to B2, then preview was updated.
3:03 I executed undo three times in desktop editors, then desktop editors and preview on DocSpace was updated A1:A2 but not B2. This is fourth problem.
