It would be fantastic if you could add a Right-to-Left (RTL) table option. So when I press the Tab key, the cursor jumps to the next box on the left. Since my language is RTL, the only issue I encounter with OnlyOffice documents is this. Additionally, it would be great if I could convert a Left-to-Right (LTR) table to an RTL one. I can accomplish this in Microsoft Word by accessing the table properties menu.
Hey @rraiszadeh
Make sure you’re using the latest version of Document Server (9.0.2), as this functionality is already supported.
In the spreadsheet editor, apply the option Layout tab > Sheet Right-to-Left, then navigate between cells using the Tab and Shift+Tab keyboard shortcuts. (as shown on the screenshot)
- Pressing Tab in an RTL sheet will move the selection to the next cell on the left.
- Pressing Shift+Tab will move it back to the previous cell on the right.
Hello Farkhod
Thank you very much for your quick reply. I am aware of this feature in the spreadsheet. What I suggested was for the Tables in Documents. When I insert a table in a document, it is LTR. When I press the Tab key, the cursor jumps to the box to its right. In Microsoft Word, I can choose this table to be LTR or RTL.
Hello @rraiszadeh ! What you are talking about is already on this Topic, work seem in progress… I mean, with the last version 9, many points on this topic has already been fixed…
Best regards
Hi again @rraiszadeh ,
Oh, I didn’t realize right away that you were talking about tables in the document editor.
Yes, that functionality is not yet available, and @Yassine is right - it’s still in development. I’ve added you to the list of people waiting for this feature.
