Do you want to: Report a bug
OS version: Windows 11
App version: 9.0.0.172 (x64 exe)
I just updated my OnlyOffice app to 9.0 version and it seems that it missing icons in home tab:
On my second PC (based on Windows 10), it’s working fine.
Could you please take a look at that? If you need any additional information please let me know.
Best Regards,
dedoci
Hello @dedoci
Please let me know that update was performed and how the app was installed initially.
Generally, you can try re-installing the app to see if this fixes the issue.
Reinstalling unfortunately didn’t fixed the issue. Regarding your questions, the app was installed using “Online Installer” from your website. When it comes to update method, I am using “Auto” updates.
Thank you for the information. Please try inspecting the items, for that right-click, for instance, Home section and in context menu click Inspect Element. It will open devtoos, please check if there are any errors in Console tab.
To be able to open devtools you need to run Desktop Editors in debug mode, please refer to this article to find out how to do that:
Thank you. Is it possible to install Desktop Editors via separate installer rather then online installer?
