Errors were encountered while processing: docspace not work
DocSpace version: deb/rpm
Browser version:
pve ubuntu 22.04 deb install
for last it not work
Configuring docspace... OK
Trying to establish MySQL connection... OK
Configuring docs... OK
Configuring openresty... OK
Configuring opensearch... OK
Configuring dashboards... OK
Configuring fluent-bit... OK
Configuring redis... OK
Configuring rabbitmq... OK
Updating database... OK
Restarting services... Job for docspace-studio-notify.service failed because a fatal signal was delivered to the control process.
See "systemctl status docspace-studio-notify.service" and "journalctl -xeu docspace-studio-notify.service" for details.
Job for docspace-api.service failed because a fatal signal was delivered to the control process.
See "systemctl status docspace-api.service" and "journalctl -xeu docspace-api.service" for details.
Job for docspace-files.service failed because a fatal signal was delivered to the control process.
See "systemctl status docspace-files.service" and "journalctl -xeu docspace-files.service" for details.
Job for docspace-notify.service failed because a fatal signal was delivered to the control process.
See "systemctl status docspace-notify.service" and "journalctl -xeu docspace-notify.service" for details.
Job for docspace-files-services.service failed because a fatal signal was delivered to the control process.
See "systemctl status docspace-files-services.service" and "journalctl -xeu docspace-files-services.service" for details.
Job for docspace-backup-background.service failed because a fatal signal was delivered to the control process.
See "systemctl status docspace-backup-background.service" and "journalctl -xeu docspace-backup-background.service" for details.
Job for docspace-identity-authorization.service failed because a timeout was exceeded.
See "systemctl status docspace-identity-authorization.service" and "journalctl -xeu docspace-identity-authorization.service" for details.
dpkg: error processing package docspace (--configure):
 installed docspace package post-installation script subprocess returned error exit status 1
 docspace
E: Sub-process /usr/bin/dpkg returned an error code (1)
Hello @liuxiang
Have you checked any of these commands?
